KE JETRONIC INJECTION SYSTEM
10 years 5 months before #49580 by manual-mecanica
KE Jotronic Injection System published by Manual-Mecanica
Good
morning I have a problem with this system is MB 560sec
The fuel scan is too
10 years 5 months before #49593 by manual-mecanica
Manual-Mecanica Response on the KE Jetronic Injection System
Hi: Looking I found in a Colombian manual the procedure for fuel pressure measurement: I will quote as is.
- (Connect a pressure meter between the cold start valve and the lower chambers inlet port of the fuel distributor, disconnect the electrical connector in the electrohydraulic actuator and then activate the fuel pump. The pressure must be between 75 and 82 psi. If the pressure is low replace filter or system pressure regulator, if the pressure is high, the pressure is high. Variation of the pressure ..) The same has a lambda sensor so to do enrichment tests to see how it responds, and refrigerant temperature sensor, as seen is quite complex, it carries potentiometer in the air flow ..
