ECU reset
10 years 3 months before #49577 by manual-mecanica
ECU reset published by manual-mecanica
Hello people !!!
I have a astra gl 1.4 Multipunto injection 1994
and has the failure of the RPM that rise and lower ... I change the step by step (IAC) Clean butterfly sensor (TPS)
It remains the same, someone explains to me how to reset the computer (ECU).
thank you
10 years 3 months before #49578 by manual-mecanica
Manual-Mecanica response on the reset of ECU
Friend, that looks like an empty hose, first check all hoses and clean the IAC seat.
10 years 3 months before #49579 by manual-mecanica
Hello friend, where are you from? I from Venezuela. Well I tell you the ideal is to place the scanner and prescribe it. But many people disconnect the battery at night and connect it in the morning. let me know how it went
10 years 3 months before #49583 by manual-mecanica
Reset the ECU, I will not give you a magical solution. Your unstable idling problem can come on some sides that you will not solve reset it.
The step by step, must be disconnected and started the engine trying to keep a slowdown as stable as possible from the pedal. turn off and re -connect the step by step. The ECU records the State and corrects, regulating the idle again.
Do this the sometimes necessary until a correct slowdown.
In addition to seeing if the rest of the components are correct- Lambada probe, PMS or detonation detector, ignition module, spark electrical system, etc.
