Ford Escort Escort Injector Problem 1.8 16 V
10 years 6 months before #49366 by manual-mecanica
Ford Escort Escort Injector Problem 1.8 16 V published by Manual-Mecanica
Good evening, I have a problem with one of the injectors of a Ford Zetec, the problem is as follows, when I open the contact the cylinder injector 1 begins to throw gasoline under pressure and if I give the other 3 to start the other 3 spray gasoline but the cylinder injector 1 continues to throw fixed jet. I have tried to change the order of the injectors and follow the problem and I have also changed the injector ramp. If someone can guide me to appreciate it a cordial greeting everyone.
10 years 6 months before #49374 by manual-mecanica
Manual-Mecanica Response on the problem in Ford Escort Zetec 1.8 16 V injector
The first thing I would do is look at the pulse of that injector, you can do it with a LED (not a lamp) if he is receiving the order, that is, the injection pulses, from the ECU, the problem you have there, it is possible that the transistor that sends his pulses sends him hump. I assume that when you changed the injectors of place the problem continues in the 1, if it was not so clear that what is bad is the injector. The other is if it has CNG team, emulators usually work those failures.
