Journey motor head torque
10 years 6 months before #49250 by manual-mecanica
Journey motor head torque published by Manual-Mecanica
GOOD AFTERNOON.
Could you tell me that Torque carries the head of a Chrysler Journey Model 2010 4 cylinders
10 years 6 months before #49285 by manual-mecanica
Manual-Mecanica Answer on the Journey Motor Torque
Look if you should place the cult, you will have to buy the Board. Normally the original joint replacements come with the adjustment specification, since the originals are constituted of a different material. And it is not normally replenished with that type of juints since to do so you must have made the rectification of plain plain and also of the block. Normally, in a replacement, the plan is made only of the cylinder head and must use a joint that attach small imperfections of the block. Therefore you must buy the Board and with it will come not only the specification of Torque but also the adjustment procedure. Greetings and luck
10 years 6 months before #49308 by manual-mecanica
