Retan crap oil escape
10 years 7 months before #49078 by manual-mecanica
Figure Cuñal Reten Oil Published by Manual-Mecanica
Hello, when I went to check the state of the car distribution strap (Honda 1.7 CDTI of 2003) I have seen that there is a small oil leak through the crankshaft area.
I don't know if it is a usual problem in this or other vehicles .... I could tell me someone if it is expensive to repair or if it is not very complicated ... a greeting
10 years 7 months before #49082 by manual-mecanica
Manual-Mecanica response on the topic Oil Retan Cñañal
Neither expensive, nor complicated, when changing the belt, you take advantage and take the retain simply scratching a couple of wood screws and pulling, a retaining of these costs about 8 euros no more ... of course you have to remove the crankshaft pine
10 years 7 months before #49085 by manual-mecanica
For someone who does not have the experience and knowledge if it is complicated, because of the economic one should not be concerned, the priority would be to re -apply to it at all costs since if the belt is wet of oil is burst and there if it would be expensive
greetings
