FUSIBLE Nº36 OPEL MERIVA SALTA
10 years 8 months before #48994 by manual-mecanica
FUSIBLE Nº36 Opel Meriva Salta published by Manual-Mecanica
For a few days I have skipped the fuse No. 36 of the 2005 Opel Meriva, (brake light, ABS, TC, ESP). I started smelling burnt rubber and term not working even the accelerator.
Now I have removed the fuse, and the engine is going well but nothing about this fuse does not work.
When I put the fuse ja I don't accelerate and I have to stop it quickly.
Urgent help Thank you.
10 years 8 months before #48998 by manual-mecanica
Manual-Mecanica Answer on the fuse theme Nº36 Opel Meriva Salta
Hello Jorben, so you comment on the smell of rubber, there is no doubt that there must be a good short circuit ... you will have to do where it comes from, some cable (+) peeled making a dough, I would not walk with the car until you find the failure, I will tell you that if you leave you removed, it may not be enough, the cars that are behind ... do not know it and .... the breakdown is also an accident. If you say that when putting it interferes with the accelerator and it smells like a burnt rubber, do not continue testing or will end up making the problem bigger. You will have to check the wiring of those elements that affect the 36 -fuse, (with disconnected battery) you can use a multimeter and check the mass insulation from the connectors of these elements (only the positive ones), well, you do not say if you have any light of the check on, you would save the work if you did a scann. Some forum partner may have already had this problem or know something like that of the Meriva. Greetings!!
10 years 8 months before #49004 by manual-mecanica
Now we are going to the usual ... Let's see what workshop steals you less. I know that it will have to be difficult to find the cause, but more difficult it will be to find some honest electrical mechanic.
Thank you so much
10 years 7 months before #49058 by manual-mecanica
Good morning. I don't know where I read of some cables cut in the rear porton that caused damage like that. Anyway, a look at Opelmeriva.activoforo.com/ . If you have a meriva it is interesting. Greetings and luck.
