How the horn D is operated an Opel Corsa B
17 years 2 months before - 17 years 2 months before #4277 by manual-mecanica
How the horn D is operated an Opel Corsa B published by Manual-Mecanica
The melting car stops working the horn and checking the fuse and is good, it will be that it has any other device that interrupts the current as a reflex and if it is so in which part of the car is it is an Opel Corsa type B ... please I need help on the subject.
Latest edition: 17 years 2 months before by .
17 years 2 months before #4283 by manual-mecanica
Manual-Mecanica response on the Re: how the horn of a Corsa 2 is operated
The current arrives at the horn, that is, you have measured the existence of voltage in the contacts that reach the horn
17 years 2 months before #4288 by manual-mecanica
Very easy to check, you enter with the diagnosis machine in comfort and make an activation of the horn. If it does not work, check the horn activation relay: it has to reach a 30, 15 and an activation mass that comes from the cabin unit.
17 years 2 months before #4303 by manual-mecanica
It does not arrive current but the supply with the battery and they are good, check the rifle and all the fuses are good and it is a Corsa B 1993-2002 ... what do I do? or where do I check now?
This is the car =>
17 years 1 month before #4575 by manual-mecanica
Manual-Mecanica Response on the Re: How the horn D is operated a Corsa B Opel
Hello.
Many times, especially if you do not carry airbag, the contactor that carries just behind the steering wheel fails, anyway to the horn, if I am not mistaken, direct current arrives, and dough when you press from the inside. If the speakers are going well and a current arrives, surely it is the part of the steering wheel.
All the best
