Blazer 95
10 years 8 months before #48826 by manual-mecanica
Blazer 95 published by Manual-Mecanica
Hello friends I have an American Blazer 95 which does not start when the fuse box that comes inside the cabin noticed a flusable flusing the diagram tells me that it is the fuse of the gasoline pump but the mechanics that the revised does not find the fault and you cannot put the skaner because when it comes to putting a fuse fuse.
10 years 8 months before #48827 by manual-mecanica
Manual-Mecanica Answer Blazer 95 theme
It is very possible that the gasoline pump was short, or if someone did any repair, they could have left a current cable reaching the ground, a way of check if it is the pump that is short, it would be disconnecting it, after you disconnect it, you put the fuse and check. I hope it serves you ..
10 years 8 months before #48829 by manual-mecanica
Disconnect the oil precion sensor
10 years 8 months before #48833 by manual-mecanica
Clearly burn the pump or there is a cable bitten to dough. Disconnect the pump file and try if the FUS jumps, if it jumps it is the wiring, if it is not the pump.
