Intostability in idle and nod
10 years 9 months before #48777 by manual-mecanica
Intostability in idle and nod published by Manual-Mecanica
:( Hello good morning, I have 3 problems in my car that is a Ford Focus 1.8 115cv tdci year 2001 the problems that I have a lot
10 years 9 months before #48788 by manual-mecanica
Manual-Mecanica Response on the topic instability in idle and pitching
If you say that it smokes a lot in the morning (I suppose that when it is cold) the problem can be of heaters (check them to see), what you should comment if the pulls disappear hot along with the smoke and if the idle is already stabilized when it is hot, or it remains the same ... greetings !!
10 years 9 months before #48790 by manual-mecanica
In the direct injection engines, the heating for cold starts are not usually very important, unless it has a km porron, I would look if there are air bubbles in the diesel ducts that go to the Idem pump in case the diesel anti -secretory valve is failing and the circuit
