Lancia Delta 2.0 16v does not start year 94
10 years 10 months before #48556 by manual-mecanica
LANCIA DELTA 2.0 16V WON'T START YEAR 94 Posted by manual-mecanica
I have a problem with a Lancia Delta 2.0 16v.
There's no power reaching the ignition coil.
I've checked the fuses and relays, and everything seems fine.
Can you help me?
10 years 10 months before #48574 by manual-mecanica
Manual-mechanical response on the topic LANCIA DELTA 2.0 16V DOES NOT START YEAR 94
I assume you don't have a kill switch installed. Have you checked that the wire going to the coil isn't cut where it comes from (try connecting a direct positive line from the battery to power the coil and see if it starts)? I don't know if in this car it comes directly from the ignition switch...? Just giving you some ideas... Cheers!
