Failure with Navigator Lincoln
10 years 11 months before #48385 by manual-mecanica
Failure with Lincoln Navigator published by Manual-Mecanica
I have a P2140 fault with the suspension of a Navigator 2001 lincoln someone could tell me where is the computer or the suspension controllers to be able to check the feed line of the inflation of the airbags thanks
10 years 9 months before #48791 by manual-mecanica
Manual-Mecanica response on the subject fails with Lincoln Navigator
Compressor Under the battery, pump relay by the same compressor area, supply module of the level sensors, on the frame of the passenger side coupled to the frame is a 15x15 plastic box with double connector
