Readin
10 years 11 months before #48303 by manual-mecanica
Idle speed. Published by manual-mechanics
Hello, I have a 2007 Toyota Hilux gasoline engine, and it has no idle at high RPMs, although it runs normally. The fuel pump was replaced and the negative terminal of the battery was disconnected. After starting, it won't idle. A Carman scanner was used, and it didn't show any error codes, but there's no signal from the throttle position sensor output voltage, and the problem persists.
