Change Renault Express Curse Board Year 91
10 years 10 months before #48180 by manual-mecanica
Change RENAULT EXPRESS BOARD YEAR 91 Published by Manual-Mecanica
Well, that kodes the butt joint. It puts me gases to the refrigeration circuit,
where could the Internet workshop manual find?
Is k buy the Board without more or for doing the planning, is there a different one?
I have doubts of all that.
What do you recommend changing you?
10 years 10 months before #48184 by manual-mecanica
Manual-Mecanica Response on the topic Change Renault Express Board Year 91
Of course ... all the packaging. And stamps of the valves., a rectified and settlement of the valves ...... luxury you have
10 years 10 months before #48187 by manual-mecanica
With a manual for the Clio, if you do not find that of the Express, you also are worth it. His would be to do it as the fellow Alvaro tells you, but you will have to assess the final price and what is worth the "van" ... If the thing came through a warm, check and change the thermostat or the leak (some sleeve, etc.) so that it does not happen again, when you have clean the plan of the cylinder head, check the plane of it with a rule in diagonal, if you are not combined, if you are not combined Diesel you would have to do some more things when rectifying .., $$$$) If you did not have oil or leak consumption problems, I would only put: COLATA BOARD- 35 euros+ DISTRIBUTION BELT, between 30 and 50 EUR, thermostat 25 EUR, and "with God" that is said ... that is not combined the cylinder head. Luck!!
