Peugeot 206 1.4
10 years 11 months before - 10 years 11 months before #48029 by manual-mecanica
Peugeot 206 1.4 Published by Manual-Mecanica
Good my problem is that the changes or marches enter, but the wheels do not move or the car goes out to your see the changes pass without pressing the clutch
I saw in
a post that the differential \ "escape \" the whole movement just as if you had a wheel in the air. 2º The primary of the gearbox or the striatum on the disc has been broken or something strange passes inside the clutch.
To know which of the two things is, lift the car so that the motor wheels are in the air. Enter first or reverse with the standing engine and wheels in the air and turn one of the two wheels with your hand.
If the wheel in front of which you move with your hand, turn in the opposite direction to the one you are giving it means that the differential and transmissions are correctly and that you have to think about the primary or the clutch.
If on the contrary, the wheel in front does nothing while you are turning the other, it means that you have a broken stick, or out of place
Thank you very much
Last edition: 10 years 11 months before by .
10 years 11 months before #48030 by manual-mecanica
Manual-Mecanica Response on the Peugeot 206 1.4
Generally what happens is when a vehicle leaves a lot of time parked or when the engine is washed and is not torch in the right shape is disc sticks to the press or clutch on together when putting the pedal only remains to disassemble the gearbox take off the disc and remove the chorion similar to the image The disc states behind the wheel, greetings.
10 years 11 months before - 10 years 11 months before #48031 by manual-mecanica
Thank you for your answer the car was underway and when you were not wanting to leave the changes pass but the car does not come out ... it is not clear to me that as art. s When the right wheel turns the left because it does not do it when the right is turned ... I am walking well I spend some
greetings
10 years 11 months before #48032 by manual-mecanica
someone? Any opinion ????
10 years 11 months before #48035 by manual-mecanica
-That is spent the clutch or greased disk, and by accelerating "skate" and does not. The striatum spent on the transmissions in this car I don't think ... but look at it by disassembling. In these boxes the differential is quite hard and it is not easy to leave a tooth to the satellite or planetary pine nuts if you go without oil in the box, which if I have seen them the rolls of the broken primary and the nut of the piñon of 5th laziness, concentrating the axis and breaking the guide of the collar, some synchro of 2nd, and the typical is also They leave the change lever loose ... Look to see what you see and tell us. Greetings!!
