How to clean IAC HYUNDAIENTRA VALVE GLS1.8 98 '
10 years 10 months before #48233 by manual-mecanica
Manual-Mecanica response on the subject How to clean IAC Hyundaielantra GLS1.8 98 'Valve
If you clean it with gasoline you should prevent it from touching the O-Ring (the rubber ring) that carries the valve because it eats it.
The constact clean is ideal for the connector pins, not for the internal part of the valve.
And yes, the valve is regulated alone
