How to clean IAC HYUNDAIENTRA VALVE GLS1.8 98 '
10 years 11 months before #47948 by manual-mecanica
I appreciate help to perform this process. I have minimum failures and I recommended me clean this valve.
10 years 11 months before #47950 by manual-mecanica
Manual-Mecanica response on the subject How to clean IAC Hyundaielantra GLS1.8 98 'Valve
Hello look, I clean the IAC valve with clean electrical contact.
10 years 11 months before #47953 by manual-mecanica
You can get it out of its place, and clean it with spray cleaners or with a moistened picound cloth, you can also completely disarm it and clean it thorough
10 years 11 months before #47960 by manual-mecanica
Thanks Angel, I don't know how to calibrate, I must take it to a workshop or there is a simple method.
10 years 11 months before #47996 by manual-mecanica
The IAC valve is calibrates alone after opening and sawing the contact several times, but in the elantra ahy barias possibilities when the release is irregular the air filter is one of them, and the other if it does not work by cleaning the IAC, the test disconnect the temperature sensor of a single cable that is the clock that is on the butt on the left side.
