Pressure 0 in idle and 30Psi if accelerated
11 years 5 days before - 11 years 5 days before #47652 by manual-mecanica
Ah is changed everything, it is a general generation repair ... but it marks 0 the oil pressure and when accelerated it reaches 30-40 and in idle low to 0 ... they believe that it can be for the camshafts but that is incrustrated in an aluminum cylinder
11 years 16 hours before #47693 by manual-mecanica
Manual-Mecanica response on the oil pressure 0 in idle and 30Psi if accelerated
Estimated, in simple words I believe that your problem does not lie in what you specify (or cylinder head, custain, camshaft) I remind you that the oil circuit begins from the carter (where the oil is deposited) the tube that sucks the oil and that it connects with the oil pump, the oil filter, the bulb or oil pressure sensor and then to the rest of the engine. Personally, I would begin by checking the proper functioning of the bulb or oil pressure sensor in the face of the doubt (for this type of engines they are not very expensive) if not, check the valve that is where you screw Oil ... Good luck
