Toyota Prado Failure 2007 Motor 5L-E
10 years 9 months before #47650 by manual-mecanica
Toyota Prado Failure 2007 Motor 5L-E published by Manual-Mecanica
Good afternoon colleagues, my consultation is as follows. I have a Prado 2007 Motor 5L-E, after changing oil, air and fuel filters at several kilometers of having left the lubricentro, it started with a 1500 rpm failure has a jump made white smoke and if it accelerated it does not pass from 2500-3000RPM does not turn on check light already checked Bommba dei Njecion thus eliminating the filter in case it was that but remains the same if anyone had that fault that can help me I thank you very much.
10 years 9 months before #47653 by manual-mecanica
Manual-Mecanica response on the topic Toyota Prado 2007 Motor 5L-E
I think the problem is the injection pump, send it to try it
10 years 9 months before #47659 by manual-mecanica
Try to purge the injectors, to see the smell of the white smoke if it is gasoleum without burning or burned oil ... lest they have passed by throwing oil and that is the problem, look at the level. It is not normal that if before changing all this was going well and now the pump draft has been left or this has been broken. Luck!!
10 years 9 months before #47716 by manual-mecanica
The problem you can have are two, you would have to tell me what a pump model has since it can happen that if it is DPCN it has an advancement of progress that can make that fault and if it is VE Bosch it may be that it lacks a prection of traffic entries the progress not to be full and it would be out of the acceleration. I could tell you that you can do haa and finally you must check the EGR valve that is not working bad greetings
10 years 9 months before #47763 by manual-mecanica
Hello ps my opinion would be. You say that this happened when leaving the lubricentro ps I would advise you to ask k type of oil, they already put these modern vehicles give problems to apply oils not recommended by the manufacturer (this because of the white smoke) the jumps check the fuel filter if it is specified
