Fiat Fiorino does not reach the spark plug.
11 years 1 week before - 11 years 1 week before #47613 by manual-mecanica
Greetings to all of the forum: I wait for their help, they brought me a Fiat Fiorino 1.5, well, this vehicle was transformed or carburetor put it therefore disconnected the wiring of the injectors.
According to the owner, but after a while I burn the ignition coil, they changed it and lasted two week to others changed the distributor and the rotor cover,
now, the module it has is a Magneti Marelli Mod.434m, Digiplex2.
The ignition coil has four pins and an exit to the distributor lid.
The problem that I have that does not reach the spark plugs therefore no part, when starting it note that the coil is a high temperature to the touch.
Therefore, it gives me the impression that the cables that reach the coil are not the one that corresponds, and they are as follows: Pin 1 comes from the sheet, pin2 of a relay, pin 3 of the Pin11 module, direct pin4 to mass. Will it be well connected?
Someone from the forum can help me give a solution to this problem, of course. Carlos
Latest edition: 11 years 1 week before by .
