Luv Dmax Diesel Motor doesn't turn on ...
11 years 2 months before #47572 by manual-mecanica
Luv Dmax Diesel Motor does not turn on .... published by Manual-Mecanica
I have problems with a Luv Dmax Motor 3.0 Diesel Estubo 3 weeks stopped and now it does not turn on .... When I start it pulls smoke Blaco for the exhaust but fails to turn on ... the filters are new
11 years 2 months before #47574 by manual-mecanica
Manual-Mecanica Response on the Luv Dmax Diesel Motor does not turn on ....
BATTERY LOAD CHECKS
11 years 2 months before #47575 by manual-mecanica
step by step.
1. Verify battery load and fluids such as oil, motor refrigerant and battery liquid.
2. Verify if the light of the light is lit on the board.
3. Verify whether it activates the injection pump targeta (put a person who placed the ON switch on and listens carefully if the injection pump makes any sound).
4. In the DLC or scan connector, make a bridge from pin 6 to mass. The switch on and immediately will begin to flash the light a thousand (Check Engine), according to the number of flashes, it will be the code. Example: It gives you the 34 code, flashes you 3 times, it turns off for 1 or 2 seconds and flashes you again 4 times.
The first flashes are tens and the following units.
5. According to the code that you throw you, you will know if the failure is of the electronic system or is a mechanical failure.
6. If you do not have the codes table for flashes, my phone number is 3007604770, my email is to report me and give you the detail of the code.
11 years 2 months before #47576 by manual-mecanica
Maybe I take a breath !!, start it with ether (start -up), while turning the Mandale Ether by the admission !!
11 years 2 months before #47578 by manual-mecanica
First of all, thank you very much for answering .... the steps that you are already made from 1 to 3 regarding the issue of bridging the diagnostic connector do not know ... are you sure that this can be done? Remember that it is OBD2 (2006) generally the DTC in these vehicles are something like this P0501 (for example) .... I would really like being able to recover the codes and I have no scanner
