Honda Civic 94 Failure and the aspiometro goes up and down
11 years 2 weeks before #47565 by manual-mecanica
Greetings I have a problem with a Honda Civic Dx 94 The esunto is that the car fails once and then takes a long time to make it the failure is that it seems that gasoline does not happen or sometimes it goes out or when it is parking unexpectedly it does not turn on or turns on failing but when the key returns or waiting for a little detime again and remains as if nothing was located something very strange. aspiometer rises and lowers that the car is not in motion
11 years 1 week before #47569 by manual-mecanica
I would see see the gas pump connector that I think goes to the awarder under the back seat to see what you see. Greetings
11 years 1 week before #47595 by manual-mecanica
Thank you for your answer ismael53 I tell you that you saw that this car has no spark in the spark plugs when I do not turn on that it is the Main Relay but what I do not explain is because the needle of the sucking aspiometro rises from one end to the other to hits the fault, the aspiometr that is in the gearbox is electronic you have some idea that it is what causes the climb of the needle
11 years 1 week before #47598 by manual-mecanica
I also believe that it can be a failure of the injection relief that affects several points such as ignition and gasoline pump and may etc ... Check it to if it is wrong or does not reach common by any bad connection and so also that when it goes, it gives a peak of voltage to the aspiometr and from there that goes up and then falls. Greetings!!
