Deflow Citroen Xantia Cuppet Screw
11 years 2 weeks before #47504 by manual-mecanica
Deflow Citroen Xantia Cuitata screw published by Manual-Mecanica
They could please help me if you have any mystery the
butt screws of a Citroen Xantia to remove it that game the key for trying to loosen it ... I wait for your answer thanks
11 years 2 weeks before #47505 by manual-mecanica
Manual-Mecanica response on the subject in the topic Citroen Xantia Screw
Loosen the screws starting from outside to the center in a 1/2 return order and continue until they release (this is not to deform the cylinder head) with a cold engine. Use a good key to a recognized brand; Quality because they usually carry a good tightening and using a tube to make lever and cost you less. (A low quality key can only bring you problems: deform the screw head, which breaks this and "des" a blow, etc.) Greetings !!
10 years 11 months before #47822 by manual-mecanica
Thank you loosening the güiro's direction while I had them with the key with the key
