Electroventillars
11 years 2 weeks before #47495 by manual-mecanica
Electroventillars published by Manual-Mecanica
Hyundai Accent 2011 electroventillars When the contact is opened, they begin to work, according to a scanner that is not from the brand has PO118 code and temperature indicator at -40, when I measure tension in the sensor plug that has 3 outputs these throw 05V, 12V, 0V, the sensor is changed, if anyone knows what this means and what values ​​should have the exit of the plug
11 years 2 weeks before #47502 by manual-mecanica
Manual-Mecanica Response on the subject electrventilators
Greetings, according to the P0118 code is the temperature sensor - high input to the circuit, indicates that the sensor signal is greater than the maximum operating test. The maximum of the 4.6 volt sensor. or 50c (-46f)
the possible open line causes of the sensor to the
damaged PCM PCM
Bad or lazy connector
damaged sensor
