Letroventillars do not work
11 years 2 months before #47385 by manual-mecanica
Electric fans not working. Posted by manual-mecanica
Good morning, I have a problem with the cooling fans on a 2011 Hyundai Accent, and I'd like to know the connection for the temperature sensor, or if anyone has the wiring diagram because it seems the computer output is failing. I tested the fans directly; they work. I used a scanner to check the temperature, and the sensor is working fine. That's the only thing the scanner detects since I don't have one for this brand.
11 years 2 months before #47386 by manual-mecanica
Manual-mechanical response on the topic of electric fans not working
Good morning, friend you check them, you must have a relay to work, additional there are also maxifusible to feed the electro, you must locate it and try them, unfortunately I notice the electrical scheme, greetings.
