Suzuki
11 years 1 month before #47277 by manual-mecanica
Suzuki published by Manual-Mecanica
Excuse me as I can know what the problem is if it is the carburetor or the gasoline pump because it does not maintain its rhythm, sometimes no chua gasoline does not know which of the two is the problem.
11 years 1 month before #47279 by manual-mecanica
Manual-Mecanica Answer on the Suzuki
If the pump is cut the carburetor, it is backed, if it is the carburetor then it only fails, but ideal would be to know if you have mechanical or electrical pump and what kind of failure do you have
