Motor does not turn on
11 years 3 months before #47232 by manual-mecanica
Motor does not light published by Manual-Mecanica
Hello:
My query is the following I have Chevrolet Luv 98 with a 4ZD1 engine that when turning it does not leave
the starting engine, the battery and is fine when taking out the spark plugs has the smell of gasoline, check the starting fuse and when giving contact it gives me 12.45 volt of the battery, change the coil and nothing.
Thanks beforehand
11 years 3 months before #47245 by manual-mecanica
Manual-Mecanica response on the motor theme does not turn on
Hello, well, when you say coil you mean that of high truth that spark. Did you try if it comes common to it? Get spark? If you have sparkles in the spark plugs it is not an electrical problem. However, if it is, the distributor could be the cause ..
but if you have a spark spark plugs or the good sparks, they also say it, and it is not a distributor problem then it could not have enough comprehensity the engine to subcress the gasoline of the garburetor, I do not know if it is carburetor or if it is injection I am not a mechanic, only because of my own experience
11 years 3 months before #47253 by manual-mecanica
Hello ... for what accounts can be an electrical problem since you say that the spark plugs are wet therefore there is no spark in them. Check the coil doing a simple test. Disconnect the cable that arrives at the distributor puts it to a few millimeters from any metal part taking the precautions for high voltage and you have to start if there is spark in the you have problems in the distributor. The same test for spark plug cables.
Others .... Check compression, distribution strap (not cut) in this type of engines are not so many failures
11 years 3 months before #47285 by manual-mecanica
It can be an infinity of things in the Chevrolet Hahaha first see if spark comes out of the distributor, if not cool coil or cut sign but I think it is the taught module always fuck
