starts and then stops Wolkswagen Polo year 1998
11 years 3 months before #47173 by manual-mecanica
The problem I have is that I give it in and then stop and change spark plugs, spark plug cables, pump relay, oxygen censor shows no checking on the board, disconnect catalytic and all the fuses are fine but still with the same symptom someone could help me
11 years 3 months before #47174 by manual-mecanica
Manual-Mecanica response on the subject starts and then stops Wolkswagen Polo year 1998
Try the exhaust pipe before the catalyst and test it, because the catalyst if it goes hot and passes through a place where it is full of water is usually closed if it falls a lot of water, also see if the exhaust tube exit
11 years 3 months before #47178 by manual-mecanica
Something similar happened to me and it was that I took too much air because a hug was lazy then started and drowned it capable of luck
11 years 3 months before #47188 by manual-mecanica
Of the cases that I have seen in Pole 1.4 AEX, in one it was stopped by a failure of the Hall sensor that carries inside the distributor, in another; He started and stopped and it was that the distribution had been skipped (a few teeth) and another was the problem of the coil's module but you say that you have already changed the coil and it goes together with the module. Greetings!!
