Greetings to all .... I have a Honda Odissey of 2005 that turns on a light of a yellow triangle with a sign of admiration in the center when it is underway and the car stops working the acceleration ,,,, this happens when it goes to more than 80 km/h ... the scan Master elM327 that I have for diagnosis but does not give me any error in the computer of the car ... , I would appreciate it .... greetings and thanks.
Good compi, that light corresponds to the VSC (vehicle vehicle control or vehicle stability control) there are many things to check to get to the problem but if you can get the electrical diagram at least you already have where to start. If you are looking on the web, one of the main problems is the vehicle deceleration, luck!
