Peuyot Expert does not start
11 years 1 month before - 11 years 1 month before #47152 by manual-mecanica
Peuyot Expert does not start published by Manual-Mecanica
Hello, I have a peuyot expert, and it does not start after being 6 or 7 months stopped, and changed the low pressure pump because it was stuck and did not go. The diesel filter changed, solved that problem checking the output of high pressure does not come out or pressure drop, it is a Boch CP1 pump, it has a flow rate valve, 12 volts arrives in terminal 2. And given mass in case the valve is the cause that the engine is not generated by the engine and remains the same, without flow. Is that valve necessary so that it generates pressure? If it had little low pressure, it would also be the cause so that there is no diesel for high pressure? In any case any suggestion to try me well
11 years 1 month before #47154 by manual-mecanica
Manual-Mecanica Response on the Peuyot Expert topic does not start
Good morning, you have made the system purge you made sure that you are not sucking air due to a connection
11 years 1 month before #47155 by manual-mecanica
