Peugeot 205 GL 1.3 NAFTA/ GNC
11 years 3 months before #47147 by manual-mecanica
PEUGEOT 205 GL 1.3 NAFTA/ GNC Published by Manual-Mecanica
Someone who can help me put the car to gasol
11 years 3 months before #47149 by manual-mecanica
Manual-Mecanica Response on the Peugeot 205 GL 1.3 NAFTA/ GNC
Check tank filter and if the fuel reaches the injectors, the problem it has is fuel or the revive air
system
11 years 3 months before #47150 by manual-mecanica
Thanks Tomorrow I will be checking
the pump normally and the filter is clean so I will play it for the air system
11 years 3 months before #47195 by manual-mecanica
I still did not look at the pump filter (the internal but the only thing I could do is see that it does not reach the naphtha filter the fuel as probable that the filter is or that the hose is punctured and take air because the pump makes the noise as it loads you, you say that it can be what I am saying?
11 years 3 months before #47241 by manual-mecanica
solved problems with the filter thanks
