Renault Twingo 16V, 2008, Motor 1.2
11 years 1 month before #47144 by manual-mecanica
Renault Twingo 16V, 2008, Motor 1.2 Published by Manual-Mecanica
Good, to this Twingo, I did injector cleaning, change the speed sensor and also change the valve lid's package, because I was driving oil, then I wore everything I went to turn on the car and nothing does not turn on the car. I put a scanner (g scan) and does not throw any code. Only in the scanner the following appears: "Cylinder 1 Recognition Not Done and the other" Target Programming Not Done ". I think that for that data I would have to take the car to the Renault, my scanner does not have the function as for reset those failures ,,,,,,,,, if anyone knows how to do it without the scanner I would appreciate, thank you
11 years 1 month before #47213 by manual-mecanica
Manual-Mecanica response on the Renault Twingo 16V, 2008, 1.2 engine.
for what I translate this is that the computer does not recognize what is the position of cylinder one. That signal is the cam sensor of the cam and the crankshaft has to match the 2. Check the sensor in case it has any blow and broke, if you took out the camshafts and cams are floating, that is, it may be that they have moved they have been broken down. Also the piece that is in the cam that gives signal may have run. You did nothing more, the car has to start: Check cam tree, distribution.
11 years 1 month before #47273 by manual-mecanica
Good ,,,, I only did the cleaning of injectors, the only strange thing I did was that I gave him very often to turn on (I think it was the error of mine), and I think that some block the ignition of the car ,,,,,,,,,,, also in a technical bulletin of the Renault, says something, that you have to apply the RZ005 command with this type of fault ,,,,,,,,,,
11 years 1 month before #47274 by manual-mecanica
11 years 1 month before #47291 by manual-mecanica
I would review the distribution draft again that therefore there may be differences in synchronism between the crankshaft and camshall. (It's just one more suggestion) Greetings !!
