Hyundai Tucson 2.0 2005 does not turn on, injectors.
11 years 2 months before #47132 by manual-mecanica
Good night, I have a problem with a Hyundai Tucson 2.0 year 2005 Diesel, I want to know why there is no current in the injectors, the high pressure pump was changed.
I will thank
11 years 2 months before #47133 by manual-mecanica
Manual-Mecanica response on the subject Hyundai Tucson 2.0 2005 does not burn, injectors.
Hello, if you do not have current +12 V in the injectors check the f8 fuse and the operation of the relay motor that feeds the same. The 30 AMP F2 fuse is in charge of giving current to the entire injector circuit and fuel pump.
I hope this helps you.
11 years 2 months before #47134 by manual-mecanica
Good night Brother and thanks for answering, we already checked all the fuses and are fine, the problem that the car had is that when it accelerated and reached 40 km/hr it went out and we chose to change the fuel pump but now it does not turn on us and we check the injectors but it does not reach their current, but the sensors yes. I would thank you for, blessings.
11 years 2 months before #47135 by manual-mecanica
A friend tells me that they can be the relay that control the injectors.
