You a problem in my vehicle
11 years 4 months before #46973 by manual-mecanica
You a problem in my vehicle published by Manual-Mecanica
I have a Ford Ranger year 98 and the hydraulic address sounds a lot I would like to know if someone can help me
11 years 4 months before #46975 by manual-mecanica
Manual-Mecanica Answer on the subject a problem in my vehicle
Hello. The noise in the hydraulic system of the direction can have various causes within which, the most common are cavitation (by air entrance to the pump suction either by some lazy clamp or damaged hose), low oil level or in the worst case occurrence of damage to the internal parts of the pump.
For the first two cases, the problem is solved correcting the condition and for the third case the pump must be repaired or changed while making flushing to the system in order to evacuate all the materials that have traveled through the hydraulic torrent and may affect other components.
11 years 4 months before #46983 by manual-mecanica
The noise of the direction is usually for little oil and if I did not clot the pump, now I check it first you want to be very loose and nothing else
