Peugeot Partner helps
11 years 3 months before #46806 by manual-mecanica
Help Peugeot Partner published by Manual-Mecanica
Hello, how I comment on the title I have a small probma in my partner of the year 99 1.9D ..... I stop working the account revolutions and I do not know if it will be a cable or electrical theme is that I have no idea of ​​cars I would appreciate your help in case it is easy to solve or not.
Thanks in advance and greetings
11 years 3 months before #46811 by manual-mecanica
Manual-Mecanica Answer on the subject Help Peugeot Partner
Hello Rubentino, check the fuses and in case you are well you will have to look at the alternator a cable that comes out of this in the terminal "W" which is the one that gives rpm signal .. then there is the possibility that the dashboard does not make good contact to the box. Greetings!!
