Hi: I have a Kia Motor Frontier 2.5 plus.
11 years 4 months before #46449 by manual-mecanica
Hi: I have a Kia Motor Frontier 2.5 plus. Posted by manual-mecanica
This with the next problem loses strength and humans black were checked injectors, hoses of the intercooler, and the turbocompressor is changed and the problem remains the same. Please help is from 2010.
11 years 4 months before #46451 by manual-mecanica
Manual-Mecanica Answer on the subject Hello: I have a Kia Motor Frontier 2.5 plus.
You should do it a diagnosis to see if it throws any code, the flow rate, atmospheric pressure sensor (in the ECU) or have some problem in the diesel pump (flow regulator) or in the injection ramp (fuel pressure sensor) can be wrong (there is no doubt that it is "burning badly" for what you comment on the black smoke and the lack of power.
11 years 4 months before #46471 by manual-mecanica
Look I have seen several 2.5 oil tankers not that year, but if you already check the tuning and the pump's avan, and everything ok is, disconnect the air hose from the air valve and further feeds and cut the smoke, it has worked at least.
