Electricxa failure in the Zetec 1.8L 16V escort
11 years 5 months before #46360 by manual-mecanica
Hello, I would like to know if someone can give me a hand
I have n escort '97 and it has a fault in the start, or rather it starts when you want, it throws it and starts safe, when it does not start it is not because it does not reach food to the coil, check the ignition relay but it is right, it also changes it but it remains the same.
Can someone give me a fact where to look for?
11 years 5 months before #46369 by manual-mecanica
Manual-Mecanica response on the topic Falla Electricxa in the Zetec 1.8L 16V Escort
It is not clear to me to start but it does not turn on, or when the key does not do anything at all?
11 years 5 months before #46374 by manual-mecanica
The engine turns normally, but does not start due to lack of food,
11 years 5 months before #46375 by manual-mecanica
I emphasize that it has a new battery, which I later checked and works very well, the alternator loads correctly and has the newly repaired starter.
11 years 5 months before #46379 by manual-mecanica
Let's see if you have problems with the immobilizer or the transfers that goes in the key ... greetings !!
