NECCITO HELP WITH MY FORD FIESTA 2006
11 years 5 months before #46294 by manual-mecanica
Neccito helps with my 2006 Ford Fiesta Published by Manual-Mecanica
What happens is that I have temperature problems, every time is not always every 1 week more or less, the engine temperature is raised, the electro does not part, the mechanic changed the thermostat and bulb all this is with a housing where all the water hoses arrive, all this is changed, also the refrigerant liquid but the problem still persists I am afraid since I will travel with the vehicle and the temperature could Running well but I see a week again heated the engine I would very much appreciate the help thanks
Greetings
11 years 5 months before #46296 by manual-mecanica
Manual-Mecanica Response on the NECCITO topic helps with my Ford Fiesta 2006
Hello good!
Well the first thing look if you have cream in the oil if you are going to have the average touch touched or some obstructed water steps, you would also recommend using high percentage refrigerant liquid since it takes a long time to heat up is a more expensive pokito but it is worth it. I hope I helped you greet
11 years 5 months before #46298 by manual-mecanica
As fellow gtro_damian tells you, you can have problems with the Board of the Cyt, look to see if it consumes water or as it tells you, mix water and oil. Then apart from this, to see if you are going to have a failure in the relay that activates the electro, that the engine of the electro and its connections are well (looking also wiring) is not going to be some of this. You should also indicate that it is "uploading the temperature" (because there are people who pass from half, alarm), if it is diesel, if you carry any exhaust perforation that prevents the emptying of the silent ... (internal countercurrent) etc ... greetings !!!
11 years 5 months before #46307 by manual-mecanica
The engine oil is well checked and has no trace of water and today the electro starts in high speed but does not stop and also the temperature rises more than half as I tell them before mind is a fault that does not appear every day is sometimes but I don't know what to do
11 years 5 months before #46309 by manual-mecanica
It seems that the electro does not supply to cool for what you say that it does not stop (we discard the bulb this evil, you say it is new), that the temperature rises more than half is not to alarm, think that it does not always circulate in the same conditions (with traffic or if it makes more heat in your area in this epoca). You will have to make sure that the radiator is clean both inside and out, that the water pump works well and circulates the water, that the degree of opening of the thermostat is correct. I can't think of anything else, if you say it doesn't consume water and the cylinder head is fine. Greetings!!
