Hot air problem
11 years 7 months before #46095 by manual-mecanica
Hot Air Problem Published by Manual-Mecanica
Hello, I have a 2012 Dodge Caliber that stopped delivering hot air, only delivers cold air.-
The fan is good
11 years 7 months before #46216 by manual-mecanica
Manual-Mecanica response on the subject Hot Air Problem
There are several causes, it can be by:
-Clide of water from the radiodor of the obstructed heater.
-Algun servomotor that open and close the gates of the evaporator box.
With more data I could help you.
11 years 7 months before #46233 by manual-mecanica
It is true can be several things, but first because you changed the fan?, also checked the thermal resistance that goes on the radiator,
