Suspension noise
11 years 7 months before #45927 by manual-mecanica
Suspension noise published by manual-mecanica
I have a lagoon of October 99, when the right shock absorber acts strongly. After having changed the shock absorber continues to hear and as a simple view, nothing damaged or any brothell is seen.
11 years 7 months before #45929 by manual-mecanica
Manual-Mecanica Response on the subject noise suspension
Pucha friend more than telling you that checks well you can't do much without listening to the noise, but look you have one thing raises the wheel in question with a cat, and checks that it has no movement or vertical or orizontal, if the cracks of the bewill bar are checkery, if the Castles of the shock absorber are cool
11 years 6 months before #45974 by manual-mecanica
One of the possibilities is that it is the suspension turret, depending on the country, it can have different names such as Casholeta. The same is the one that is subject to the suspension spring from the upper part, together with the shock of the shock absorber, many times when this piece is damaged, you notice it before large blows and it is even difficult for you to locate the problem if you do not disarms it since, no matter how much palanques trying to verify strikes may not be noticed. To replace the workforce is the mosma that would cost you to replace a shock absorber. On the other hand, if it was not a gang of grills or stabilizer bar, but all this is located by raising the vehicle and palanqueando with a bar each suspending sector. Greetings and luck
