Nissan Sentra helps.
11 years 7 months before #45838 by manual-mecanica
Nissan Sentra helps. Posted by manual-mecanica
Greetings Technical colleagues, I have a problem with a Nissan Sentra 2.5 Lts 2005 - 06, the MAF sensor is failing but I do not locate the electrical diagram to test said sensor, this sensor and whose connector is is 5 cables but I do not locate the information since all I locate you of 4 cables, if any of you had this information I would appreciate it very much, thank you ...
11 years 6 months before #45992 by manual-mecanica
Manual-Mecanica response on the subject Help Nissan Sentra.
Good compi, it is clear that if the sensor has 5 lines, it is because it has the admission air temperature sensor included, a 12 -volt signal for the MAF, one of 5 for the IAT. A land and two returns, with a multimeter you should discard one by one. greetings!!!!
11 years 6 months before #46049 by manual-mecanica
HELLO
11 years 6 months before #46051 by manual-mecanica
here are the diagrams
