Luz Stop Jeep Grand Cherokee 1997 does not turn on
11 years 7 months before #45726 by manual-mecanica
Hello, good day again I come here requesting your help and I tried everything I already went with 6 electric and nothing of all
commented one day a month ago in the pantala of the walking I fail in light it transcends and immediately it is not taken much importance since it took immediate Account that I did not turn on the Stop Light
1 check fuses
2 Change all bulbs
3 change the brake switch that is located where the brake pedal
4 change the harnes of that switch
and do not turn on the stop light
if it passes a chorio tada time you turn on the rooms and the crowns they are the same photo transceero but the stop does not, someone who can help me the Manuel and speaks of a brake I don't know where that blessed sensor is waiting waiting for that to be,
without a pregnant, I require your support because it is a risk to manage in these conditions.
11 years 7 months before #45727 by manual-mecanica
Manual-Mecanica Response on the topic Stop Jeep Grand Cherokee 1997 does not turn
Hello, as I see you have checked almost everything, but you should look if 12v arrives. Among the positive where the bulb and dough goes, lest you have a cable cut by some blow in the bumper ... greetings !!
11 years 7 months before #45735 by manual-mecanica
I don't know if I understood well, two of brakes work for you but the third right? If so, the solution is easy, it is wired again until the third, if you do not turn on, it is necessary to check if current arrives in 12+ and if you present the earth and now, the wear or loss of current putting ours
11 years 7 months before #45742 by manual-mecanica
I tell you to turn on the rooms that is the same photo as the brake light, but it does not turn on the stop or brake light from above or the two sides I will check that if it arrives, the question passes the question is whether it does not arrive current in theory I should not even turn on the rooms is correct or I am bad, there is a way to adapt it to it : Sick:
11 years 7 months before #45743 by manual-mecanica
If you do not light any of the braking lights, surely the problem comes from the pedal switch; That the rest of the lights are turned on, it has nothing to do, because they are other positive ones that reach the pilot's terminals, you will have to get one that comes from the pedal to one of the two pilots that will also communicate the other pilot for the braking lights (it also depends on the car model)
