Renault 2.2 dci fuel loss
11 years 8 months before #45551 by manual-mecanica
Fuel Loss Renault Motor 2.2 DCI Published by Manual-Mecanica
Hello friends, here I write to another problem again, it turns out that four days ago fuel began by some small "plastic distributors located on the injectors, these devices are fixed with a clip to the rest of the injector, I attach a photo to clarify.
They would greatly add their comments or if anyone had a similar problem.
Thank you
11 years 8 months before #45553 by manual-mecanica
Manual-Mecanica Response On the Fuel Loss Theme Renault 2.2 DCI Motor
Hi Alfredo2264, that is the returns of Gasoil, surely, or is not well involved, or a Torira Board has been damaged that carries at the tip (inside), disassemble it to see. Greetings!!
