Problem with Cavaleir 2.2 1999
11 years 8 months before #45547 by manual-mecanica
Cavaleir Problem 2.2 1999 Published by Manual-Mecanica
Hello friends, I send my cavalier to adjust with mechanic
according to the change Rings change the vila metals
rectified the crankshaft and gave it the head
and the 100km started a noise is taken to warranty
and the Czech and the Czech time to measure that the pistons do not serve and the rings that because I gave it a warm Alcarro. He is cheating
11 years 8 months before #45554 by manual-mecanica
Manual-Mecanica Response on the problem with Cavaleir 2.2 1999
If you change the rings, answer that of this, that by a warm you do not "go", and if you take a warm with 100 kmts after repairing ... or I do not pur well, or do not amount well the engine, it wants to deceive you, the same the same noise that started sounding is something that has been left loose ... or a washer that is placed to him, for some duct of admission ...
11 years 8 months before #45568 by manual-mecanica
I totally agree with Isma claims or even see another workshop to verify it because that would have to solve it is their fault
11 years 8 months before #45572 by manual-mecanica
Friends, I tell you that you disassemble the pistons and 3 roson in the monoblok and the rings were damaged according to me taught me and are spent from the sides they think
11 years 8 months before #45580 by manual-mecanica
It seems to me that the amount "of the setbacks ..." or the pistons (against the arrow or position) or the segments (down ..) That is what it seems to me ... Be care It seems to me that he has done this, if not, I say, I would not have repaired and I would have told you about rectifying cylinders, etc ... and on top of that in a cylinder, but to top it off ... in three of 4 ... I do not tell you more, companion, say it very clearly ... !! that does not tell you movies !!!
