Peugeot 306 xs 1.6 Don't burn well and I'm crazy
11 years 10 months before #45593 by manual-mecanica
Hello Compadre Look I had a similar problem and check all the sensors, check wiring and all the only thing I had was the ignition module that in the Mio case is from the TU5JP engine with Bosch MP5.1 injection which is incorporated into the computer if you know electron The manual I send you
there appear the different types of injection the bosch the magneti marelli
luck
11 years 10 months before #45594 by manual-mecanica
luck
11 years 10 months before #45595 by manual-mecanica
luck
11 years 10 months before #45596 by manual-mecanica
luck
11 years 10 months before - 11 years 10 months before #45598 by manual-mecanica
Hello compadre look I had a similar problem and review all the sensors check wiring and all the only thing I had was the ignition module that in the myth The manual I send you
luck
Last edition: 11 years 10 months before by .
