pounding
11 years 8 months before #45502 by manual-mecanica
PEADO PUBLISHED BY MANUAL-MECANICA
Hello friends kisiera if anyone can help me with my mechanical problem. I have a 19 -TS reindeer and it has a boured k seem to be valves but the regulated without niguna improves the car has strength part without problems (it sounds like a oil tanker) if someone happened to someone I solve it .....
11 years 8 months before #45503 by manual-mecanica
Manual-Mecanica response on the topic
Let's see game of a connecting rod caps ... To see this you will have to disassemble the oil carter (if this is, you do not walk or ruin the full engine) Greetings!
11 years 8 months before #45522 by manual-mecanica
Hi Meckano.
You do not mention if you have smoke, if the noise is not like metal to wood and if it is dyeing, check them, they can be spent, this damage does not generate smoke.
Luck.
Miguel
