Failure in Peugeot 306 xs 3 doors 1.6 year 2000
11 years 9 months before #45238 by manual-mecanica
Good morning, I recently bought a 306, of mechanics you know little and nothing, I have the problem, when the car is detained and I start it in First or R, if I do not release the clutch very slowly vibrates the car a lot, eventual mind if I move it almost regulating it does not do so, but usually it does it to me, this makes it only hot, if the car is cold.
Can anyone guide me a little about the possible problem?
Thank you!!!
Greetings
11 years 9 months before #45239 by manual-mecanica
Manual-Mecanica response on the topic in Peugeot 306 xs 3 doors 1.6 year 2000
Hello, Javo22, check the engine tacos, may be broken ... it can be that "the whole engine moves", apart from this, also to think that in cold the engine is not "soft". Greetings!!
11 years 9 months before #45240 by manual-mecanica
Now I read that you say that it does not do it in cold, then tell us if it is diesel or gasoline (to see what engine it has) What do you mean that it vibrates a lot? As if it got caught?
11 years 9 months before #45241 by manual-mecanica
Hi Ismael, it is 1.6 gasoline motorcycle, in cold it does not and when it is hot and it does, it vibrates a lot, it is heard how the front train is shaken if I leave it, if I leave almost without accelerating, just regulating, it makes it very soft.
Thank you
11 years 9 months before #45242 by manual-mecanica
Hi Javo22, if you say that the front train is "shaken", then they can be the engine tacos, look to see how I already told you, put a march (4th) with the engine stop You leave slowly, the engine does not move so much (you notice less), but I already say, look at it in case you have any element of the suspension loosened and have some dislike ... Be careful that you do not know the history of the car. Greetings!!!
