Oil from the exhaust tube
11 years 10 months before #45170 by manual-mecanica
Oil from the exhaust pipe. Posted by manual-mecanica
Hello everyone, this is my first time on this site and I find it quite interesting. I have a 2005 Nissan Primastar 100hp dCi, which is my go-to vehicle for everything, as I also use it for work. Over the years and with the mileage, problems have started to appear, and with the way things are these days, I can't afford to have it repaired at a garage.
That's why I need your help.
The most urgent problem is the oil leaking from the exhaust pipe. What do you think it could be?
Thanks.
11 years 10 months before #45171 by manual-mecanica
Manual-Mechanics' response on the topic of oil coming from the exhaust pipe
It's probably the turbo.
11 years 10 months before #45172 by manual-mecanica
Welcome to the forum, Josearatec. I'm not sure if you're referring to oil, oil burning smoke, or condensation (dripping).
If it's oil, the only thing I can think of is the turbocharger; the ceramic bearings might be worn. But that oil would burn and come out as smoke. Does this happen when the engine is cold? Is it consuming oil? If so, the only other cause I can think of is the turbocharger.
11 years 10 months before #45200 by manual-mecanica
It looks like the turbo bearings; you'll probably have to spend some money... : S
