VW Pointer problem
11 years 10 months before #45104 by manual-mecanica
Problem with VW Pointer published by Manual-Mecanica
Hello, good afternoon, I have a problem with a VW Pointer the problem is that when accelerating the car drowning and it is well triggered TPS TPS IAK VALVE IAK Oxygen Sensor and the MAF and nothing that I also matched if we were check if it was out of time and not also checked if there were any current jump and nothing changed the gasoline pump yy does not match someone. Pointer 2001 Motor 1.8
I hope someone can help me in advance ...
11 years 10 months before #45105 by manual-mecanica
Manual-Mecanica Answer on the problem with VW Pointer
Hello, I advise you to check spark plugs, after starting it to see how they are, (wet, very black, or white), according to this you will know if there is an excess problem or fuel defect, you can have a problem in the regulator (fuel excess) or pump feeding problem or in this, neither do you discard a problem on (spark plug cables etc.) Greetings !!
11 years 10 months before #45127 by manual-mecanica
If you give you pulls, or you have started starting badly, it can be the ignition module (I think it goes together with the ignition coil)
