Lights are back
11 years 9 months before #45093 by manual-mecanica
Lights march back published by Manual-Mecanica
Hello, I'm new on this page! I have an R19 Mod99 diesel, I am putting it in a way, let's say that I find that it does not have the back lights, without lights, or holder lights and without the cables, I make a way with the things of the car, if someone can guide me to be able to do the installation I would appreciate it, and anything I can contribute .... the theme of refrigeration and brakes will be done Fix, well, any aid welcome !!!
11 years 9 months before #45099 by manual-mecanica
Manual-Mecanica Response On the topic Lights Going back
Hi Seba3003, welcome to the forum !!, in the Caja Changes, you will have a back switch, this is usually found over time, (check it), as for the portalamparas, look for some in a scratch and pick them up the plugs cut by the cable, so that you can connect it in the wiring of your car, observe if your car has the car) Here we are. I am already for him !!
** (CAUTION When disassembling the switch from the gearbox, if it is in the lower part, you may get oil) **
