drowning / jaloneo
11 years 9 months before #45049 by manual-mecanica
Manual-Mecanica response on the topic drowning / jaloneo
A detail that had not commented, on the board on the temperature indicator, when there is a failure for drowning, the needle is destroyed.
11 years 9 months before #45050 by manual-mecanica
Hello everyone, FloresGarcia, I was an important detail, if you do not handle the multimeter to test the circuits, I recommend you try the ECU of your car (possibility that this bad) in another, that is to say the ECU that is suspected with malfunction in the car that works ok, this is to avoid if there is an electric cut in the circuit of your car can affect the good ECU, I do not know if I explain well. Ok, not the reverse. greetings.
11 years 9 months before #45051 by manual-mecanica
Hello everyone, FloresGarcia, if the light of the burning chek is destabilized and also has no code (bone code 55 in Nissan) it is likely that it is the ECU, but it recurred the indications of the previous post, Ecu Mala in Electric Ok system, not the reveal.
11 years 9 months before #45052 by manual-mecanica
Thank you again, the test will be done. Greetings
11 years 9 months before #45053 by manual-mecanica
Hello everyone, FloresGarcia if your ECU works ok in another car, there are problems in the wiring. If you solve the problem, let us know, if the symptoms persist too.
